Keyless Code
Old Sep 4, 2011 | 05:49 AM
rdrunner1974's Avatar
Default Keyless Code
Where on a 2002 Mountaineer with 3 row seats is the factory keycode located? I traded for the car and there is no owners manual or info as to what the code is. I do have instructions on how to change the code, but I need the factory code to do that.
Thanks for any help.
Old Sep 4, 2011 | 02:58 PM
Default keyless code
I found it. Had to remove the trim around the passenger side rear door. 1st remove the upper trim where the seat belt is, pull seat belt out and block it from retracting (wrap around the seat) Then pull out on the lower trim panel, does'nt need to be taken completly off. You will see a black plastic box that has 3 connector plugs on the bottom of it, it is held in by clips and raising up at the ends will allow you to lift it up enough to see a label.
This is the Central Security Module as the label will indicate. There are 5 larger numbers on it like 79481, that is the factory code. The code can be changed by the owner, I think the owners manual tells how.
The factory code should allways work.
Reborn
Aug 24, 2014 08:15 AM
Eastbradyhs
Oct 17, 2007 08:40 AM
logan1223
Nov 21, 2006 09:21 PM
jbruck
Jun 16, 2006 12:13 AM
tata0522
Dec 4, 2005 04:13 AM
