TRANSMISSION MYSTERY
Old Aug 29, 2008 | 09:45 AM
MAGICRON's Avatar
<TABLE cellSpacing=1 cellPadding=1 align=right border=0 valign="top" itxtvisited="1"><T itxtvisited="1">
<T>
<TR itxtvisited="1">
<TD itxtvisited="1"><! PUT THIS TAG IN DESIRED LOCATION OF SLOT Forums_ROS_300x250_noad ></><! END OF TAG FOR SLOT Forums_ROS_300x250_noad ></TD></TR></T></T></TABLE><! AdSense square code >I had aproblem with my 97 Mountaineer shifting lazily. It wouldn''''t shift until about 4000 rpm. The transmission shop tried changing out all the valves to no avail and finally decided it must be something internal so they rebuilt it. It shifted beautifully until we shut off the motor and started up again and it went back to shifting incorrectly again. Everytime we disconnect the batteryand reconnectit works like a charm. Anyone have this kind of a problem? If so what was the solution? Maybe something in the computer?Edited by: MAGICRON
Old Aug 31, 2008 | 08:43 AM
jason sereiko's Avatar
Yes it is the computer. These have computer shift points for the trans. they can simply hook up a hand held scan tool and recali the shift points with oput touching a tool. If it is resetting when you do the battery thing then it must be a computer problem, if the recali does not fix it then you need a new computer for the car. Have them update the shift points with the latetestr version they have. usually the dealer has the best programs
MercAdvisor
Aug 17, 2009 10:44 PM
Rex
Aug 11, 2009 04:11 AM
arjenmor
Jan 8, 2007 02:07 PM
stumped
Apr 21, 2005 03:02 PM
beech
Apr 10, 2005 06:06 PM
