-   Mystique (https://www.mercuryforum.com/forum/mystique-20/)
-   -   Alternator Removal 1998 V-6 (https://www.mercuryforum.com/forum/mystique-20/alternator-removal-1998-v-6-a-2116/)
polaristx398 Oct 28, 2008 09:53 PM
Please tell me what i have to remove and what bolts off the alternator. Thanks ,Dan Edited by: polaristx398
conan312 Nov 15, 2008 07:01 AM
First release the tension on the belt and remove. Then move anything that is hampering you from getting to the alt. bolts. Don''t forget to take the neg. batt. terminal off before you start. Good luck!
TourDeForce Dec 17, 2008 08:43 AM
I know this is a bit late, but for those searching in the future...
The V-6 Mystique is a tricky one. Here''''s what I''''ve done:
    CRITICAL NOTES:
    <UL>
    <LI>The alternators were VERY tough on these cars. Aftermarket units will typically FAIL within a few weeks, if not within a few hours. Don''''t waste your money on them, get Ford factory in this case. I''''m all for saving money, but this is one of the few areas where saving on parts is a very bad idea.
    <LI>When you re-install start with the lower bolt but don''''t tighten it untilyou use the pivot trick to get the upper ear into position, then use the 10mm bolt to snug the bracket to the engine block &amp; the upper ear will slide into place on it''''s own. Don''''t frustrate yourself trying to do this by hand, let that little 10mm bolt do the work for you.
    <LI>Be certain you get the bolts all tightened up. So much up &amp; down, over/under the car that it''''s easy to forget one.</LI>[/list]
    Took me about 4 hours first time I did one of these on my Contour. The Mystique replacement took under 1 hour since I had soooo much practice with aftermarket alternators on the Contour. [img]smileys/smiley11.gif[/img]Edited by: TourDeForce
    polaristx398 Dec 17, 2008 04:30 PM
    Awesome detailed replacement,
    thanks Dan
    drifterz73 Mar 29, 2015 05:49 PM
    i am still having difficulty in removing this alt.
    was told i could remove the alt bracket and then the bracket and alt would come down.
    but i cant find all the bolts to remove the bracket. and i cant gain access to remove the alt bolts.
    please help new hear and new to the mercury v6.
    Does anyone have pix for all the necessary part removal...
