brake pull on 00 mistake,
Old Dec 22, 2009 | 10:46 PM
letitsnow's Avatar
Default brake pull on 00 mistake,
has new hoses, calipers,brackets,pads and rotors and pulls like a mother when braking. Pulls to the right real hard. any Ideas, tsb? I am at a loss.
Old Dec 26, 2009 | 05:29 AM
conan312's Avatar
It sounds like the caliper on the driver front is malfunctioning. I assume there are no leaks, all parts were correctly installed, and you have a good pedal feel? If you want you can try and bleed out that caliper again. Maybe it is airbound.
Old Dec 26, 2009 | 11:49 AM
I would suggest bleeding them again too. Also, check for kinks to the hard lines going to the left side. it could also be loose links (tie rod ends) or even control arms. when the forces on the front wheels go from moving the car to stopping the car, that may cause a shift in the control arm if the bushings are shot and cause the car to pull.
oldermercintx
Oct 6, 2010 08:14 PM
stangcbr
May 15, 2010 10:37 PM
Krollmonster
Mar 15, 2010 07:54 PM
