1995 Mystique Engine cooling fan
Old Mar 13, 2006 | 03:41 PM
Coachkey22's Avatar
I have a 95 Mystique and I am having problems with my cooling fan. I have replaced the fan, I have replaced the TPS. I know the wiring is good to the fan motor. I can jump across wires at the fan relay in the fuse box and the fan runs, but when I hook it up and run it normal the fan nevers comes on. Does anyone have any ideas what else I could check to see if I can fix this problem.
Thanks
Old Mar 16, 2006 | 02:50 PM
Patrick's Avatar
Administrator
TPS? throttle position sensor?
there should be an electronic trigger...
Old Mar 17, 2006 | 03:38 PM
MercAdvisor's Avatar
There may have been a recall for this problem if you give me your vin I can check to see if any recalls for this problem are out there for your vehicle.
Old Mar 21, 2006 | 08:49 PM
Coachkey22's Avatar
First off I want to Thank everyone that sent a response to my problem. But I was wondering what Patrick was indicating when he stated that it might be the TPS.
More Info:
The fan runs with the A/C on.
If I unplug the Temp send unit the fan comes on at full high speed.
I have traced power to all of the fuses and the wiring is all good.
The thermostat is opening.
What temp does the fan come on at ?
I am going to but the book called "Ford electrical Vacuum diagram troubleshooting manual. Does anyone have this book, and is it any good for overall problem solving. I have found the hanes book is not helpful at all.
Once again thank you to anyone that may be able to solve this problem, I have everyone scratching their heads around here.
Thanks
Coachkey
terryeckel
Sep 18, 2013 01:30 PM
dudu.soft
Jan 11, 2009 05:23 AM
kevin1467
Aug 17, 2008 05:06 PM
Bobbin Jones
Aug 13, 2008 05:31 PM
Stray Dogs
May 19, 2006 08:42 AM
