2003 Mercury Grand Marquis Cooling system
Old Jan 12, 2020 | 12:35 PM
phrannyh's Avatar
Default 2003 Mercury Grand Marquis Cooling system
2003 Mercury Grand Marquis. Overheated. Car is "like new, less than 96,000 miles.
Now check engin light stays on. What to do?
Old Jan 12, 2020 | 03:25 PM
Default Overheated -- CIL Stays On
Now check engine light stays on. What to do?
First, disconnect the NEGATIVE battery cable for 30 minutes -- then re-connect the cable.
Check the coolant level and fill to the "COLD" line before starting the engine.
Start the engine and watch for signs of leaks as the engine warms up.
You will have to determine why the engine overheated in the first place.
Replace Thermostat with STOCK Temperature unit (192-195 degrees F.), if necessary. Motorcraft RG-571 is correct gasket, goes ON TOP of thermostat -- Thermostat is installed with Springs DOWN.
Paulp
Apr 2, 2011 07:11 AM
carl5242
Apr 2, 2011 07:08 AM
Mountiandi
Nov 3, 2008 07:16 PM
gl2001_cougar
Oct 23, 2008 12:11 PM
geri
Sep 4, 2007 08:18 PM
