2006 montego keypad doesn't work
Old May 30, 2017 | 01:58 PM
tburnside312@gmail.com's Avatar
Default 2006 montego keypad doesn't work
On my montego the keyless entry pad doesn't work, it doesn't even light up when you touch a button, what can be wrong?
Old Jun 3, 2017 | 01:05 PM
Per FORD Motor Company --
Before doing ANY electrical work, disconnect the NEGATIVE battery terminal.
On to the problem--
First, find and check the fuse -- replace with proper size fuse, if necessary.
Check keypad operation before proceeding.
All of the electrics for the keypad are inside of the door.
Check U-Tube videos for replacing the keypad on your year/make/model.
New keypads can be had at RockAuto.com or Amazon.com
But before you spend any money, make sure that your existing wiring is properly insulated and all systems are GROUNDED.
Good Luck !!
2006montegoman
Nov 18, 2014 09:13 AM
FAUSTOCG
Jun 16, 2013 01:33 PM
numberonepugs
Dec 16, 2008 02:56 PM
ericfoster3
Oct 30, 2007 09:43 AM
scheuer1
Aug 29, 2005 04:30 PM
