-   -   74 Marquis rimblow problem (https://www.mercuryforum.com/forum/new-member-area-8/74-marquis-rimblow-problem-3028/)
black_eight Jun 23, 2009 08:57 AM
Hi,
since the horn in my 74 Marquis doesnŽt stop to sound, I suppose the rimblow is defect. Is there any chance to renew these?
Uwe
slymer Jun 23, 2009 09:29 AM
The rubber has probably shrunk causing a constant contact. I guess if you could replace the rubber in the wheel, that would fix it, but I wouldn't know how to go about doing that. You could always try to find a steering wheel from a 75 or so that didn't use the rim blow horn ans swap them out.
black_eight Jun 24, 2009 08:46 AM
... thanks!
slymer Jun 24, 2009 04:37 PM
you're welcome. and btw... nice car. I wish my car looked half that good.
black_eight Jun 25, 2009 06:11 AM
... nice car
thank you. IŽd to do little to bring it to that condition, except for the 460 engine which had to be replaced because of main bearing failure. As an intended side effect, the new (modified by www.hemifordman.com) engine has a couple of additional HP. IŽll add some current pictures soon.
