95 merc
1995 Grand Marquis GS Restoration.
Engine is stock, except for slight mods -- Air Box Snorkel removed - cool air is ducted from forward of the engine compartment. K&N Re-usable Air Filter. Bosch Electric Fuel Pump. Mallory Adjustable Fuel Pressure Regulator -- 35 psi. @ 800 rpm. Bosch Series 3 - 19lb. Fuel Injectors. Bosch Mag-Core Ignition Wires. Bosch Double-Iridium Spark Plugs. Bosch 130-Amp Alternator. Gates RPM Series Serpentine Belt. Gates Drivalign Belt Tensioner. Dual Exhaust - Walker H-pipe, MagnaFlow 2" Glasspacks, Walker Tail Pipes. B&M 13,000 b.t.u. Transmission Cooler. B&M Transmission Shift Improver Kit. B&M Transmission Drain Plug. Cast Aluminum Differential Girdle. Energy Suspension Urethane Control Arm Bushings (upper & lower) ADDCO 1 1/4th" Front Anti-Sway Bar, with Energy Suspension Greaseable Urethane Bushings. ADDCO 1" Rear Anti-Sway Bar, Urethane Bushings. Energy Suspension End Links with Urethane Bushings (rear). Eclipse Brake Calipers (front & rear). ACDelco Drilled & Slotted Brake Rotors (front & rear). Motorcraft Police Brake Pads (front & rear). D.O.T. 4 Brake Fluid. 98T Goodyear Assurance ComforTread Touring Tires. 5 "Italian Lace" 15" alloy wheels. MOOG Greaseable Ball Joints, Tie Rods, Idler Arm, End Links (front). HELLA Daytime Running Lights. Tinted Windows. |
