95 merc
Old Nov 29, 2016 | 01:27 PM
95 MERCChuck Hallowell's Avatar
Default 95 merc
1995 Grand Marquis GS Restoration.
Engine is stock, except for slight mods --
Air Box Snorkel removed - cool air is ducted from forward of the engine compartment.
K&N Re-usable Air Filter.
Bosch Electric Fuel Pump.
Mallory Adjustable Fuel Pressure Regulator -- 35 psi. @ 800 rpm.
Bosch Series 3 - 19lb. Fuel Injectors.
Bosch Mag-Core Ignition Wires.
Bosch Double-Iridium Spark Plugs.
Bosch 130-Amp Alternator.
Gates RPM Series Serpentine Belt.
Gates Drivalign Belt Tensioner.
Dual Exhaust - Walker H-pipe, MagnaFlow 2" Glasspacks, Walker Tail Pipes.
B&M 13,000 b.t.u. Transmission Cooler.
B&M Transmission Shift Improver Kit.
B&M Transmission Drain Plug.
Cast Aluminum Differential Girdle.
Energy Suspension Urethane Control Arm Bushings (upper & lower)
ADDCO 1 1/4th" Front Anti-Sway Bar, with Energy Suspension Greaseable Urethane Bushings.
ADDCO 1" Rear Anti-Sway Bar, Urethane Bushings.
Energy Suspension End Links with Urethane Bushings (rear).
Eclipse Brake Calipers (front & rear).
ACDelco Drilled & Slotted Brake Rotors (front & rear).
Motorcraft Police Brake Pads (front & rear).
D.O.T. 4 Brake Fluid.
98T Goodyear Assurance ComforTread Touring Tires.
5 "Italian Lace" 15" alloy wheels.
MOOG Greaseable Ball Joints, Tie Rods, Idler Arm, End Links (front).
HELLA Daytime Running Lights.
Tinted Windows.
cowboy
Mar 14, 2017 03:08 PM
foxchaser2000
May 19, 2006 12:47 AM
VaDancer
Dec 12, 2005 06:00 PM
klulessone
Apr 25, 2005 09:54 AM
The Anti Hero
Feb 2, 2005 01:13 AM
