<DIV>Last week Aug 7th, Microsoft released the latest security patches for Win 2000 and XP and apparently their patch is causing intermittent crashes when trying to load web sites that use HTTP 1.1 or compression.
Here is the workaround to fix the problem: WORKAROUND To work around this problem, follow these steps: 1. Start Internet Explorer 6. 2. On the Tools menu, click Internet Options, and then click the Advanced tab. 3. In the Settings box, click to clear the Use HTTP 1.1 check box under HTTP 1.1 settings, and then click OK. </DIV> <DIV></DIV> <DIV>BTW: This workaround was extracted from Microsoft's Knowledgebase article found here: http://support.microsoft.com/kb/923762</DIV> |
great job boys[img]smileys/smiley1.gif[/img][img]smileys/smiley1.gif[/img]keep up the good work! |
recently i tried to install IE7 from cd .and for installation it
requires a net connection .so i connect to net.IE 7 installed but not workin .at the same time mi m also using FF .so this is because of FF.can we not both simultaneously????? but after this i just unstall the IE7 . than previous IE6 is also not workin ..error say..msvrdl.dll mising.. and in C:\Program Files\<b style=": rgb(255, 255, 102);">Internet[/b] <b style=": rgb(160, 255, 255);">Explorer[/b] one files named "iedw" is created and its descreption is IE crash detection ..and this file is not deleting .. how can i use IE now..... |
both should run at the same time.
You might have to reinstall. you can download the IE7 installer from microsoft here. it''s 14.8 meg. this is the version for windows XP SP2/3. other versions are linked to at the bottom of the page. Reinstalling should fix the not loading issues. if not, try uninstalling it and installing ie6sp1 that can be downloaded from microsoft here |
