-   -   Hazard light on 95 Mercury Grand Marquis (https://www.mercuryforum.com/forum/new-member-area-8/hazard-light-95-mercury-grand-marquis-10575/)
iroky2000 Aug 14, 2019 03:07 PM
Hello everyone,
I have a 95 Mercury Grand Marquis that has been sitting for about 10 - 15 years.
I need to get it brake and light certified.
Brakes are done but I have an odd issue with the lights.
I get all turn signal, driving lights, and brake lights working.
When I put the hazards on, the right front will not blink. It works fine for the turn signal, just not the hazard.
I have not replaced the flasher relay yet, not sure that would be the issue.
Any ideas?
Thanks for any suggestions.
95 MERC Aug 15, 2019 11:04 AM
Never had that problem with the 95 MERC, even after changing all the bulbs to LEDs.
I have the wiring diagrams for all models of 95 Grand Marquis and Town Cars, but can't find any description of your problem, or a solution.
Replace the Flasher, and see if it fixes the problem. If not, you MAY have to replace the Emergency Flasher SWITCH.
Keep us posted.
iroky2000 Nov 25, 2019 10:15 AM
Solution
I replaced some dash lights, like the turn signals, and the problem was solved. A day later it came back...
I took it all apart and noticed if I wiggled the hazard button, it would start working. I took the turn signal assembly apart and found a LOT of corrosion in the contacts. A lot of cleaning and reassymbly later, it now seems to be working good. The corrosion on the contacts prevented just the right front from coming on.
I never would have thought....
95 MERC Nov 25, 2019 01:38 PM
Rust & Corrosion
Ya done good !! I didn't think of corrosion, either, as I live in the desert, and The 95 MERC is totally rust-and-corrosion free.
https://cimg0.ibsrv.net/gimg/www.mer...eb75ecd6aa.jpg
Like No Other
