01 Sable LS missing
Old Aug 14, 2006 | 02:49 PM
vicar1's Avatar
I have a 2001 Sable LS with Duratec with a problem I have not been able to figure out. Every once in a while the check engine starts flashing and the engine starts missing. The A/C also stops blowing cold when this happens. I read the codes and got "cylinder 6 misfire". Checked the injectors and found a bad connector. Replaced the connector and the injector but the problem is still there. Replaced the spark plug and the wire for #6 with no improvement. Switched coils with friend's Taurus, still the same. The codes I am getting are PO306 and PO174. Took it to our Ford stealership and they said they would have to 'get inside the engine' to check it out. 'Maybe a piston or a valve'. Could this be right? It sounds like more $$$ than I can afford. PLEASE HELP!!!
Old Mar 15, 2007 | 08:39 PM
ice1kat's Avatar
There are several things that is still could be, one is you MAF and the big one is a vacuum leak, whichcould be on your PVC line. I would check these first before I had the shop to "get inside the engine".
2010_mercury_mariner
Apr 22, 2015 10:54 AM
jfiguere678
May 28, 2014 05:57 PM
slymer
Dec 26, 2009 05:31 AM
txboxergirl
Jan 27, 2009 04:41 PM
MItoplock
Jan 22, 2009 07:40 PM
