02 sable rear brakes
Old Mar 24, 2010 | 08:27 PM
Doug T's Avatar
Default 02 sable rear brakes
Trying to replace drum and shoes.
On the right side. I got the drum off and replace shoes and springs, Parts came from Autozone. Question.. the large spring that goes across the bottom between the shoes has no tension on it. Did not notice this before i removed the old one, is this normal?
On the left side, I cannot get the drum off. Tried to remove the rubber plug on the backing plate but cannot see into or feel the adjustment wheel with screwdriver. Any suggestions on how to the drum off?
Not worried about re-useing it, already have a new one. Car has 185k and I did notice that the pin that holds the holding spring is loose.
Thanks for any advise, going on vacation tomorrow and will check when I get back.
hvymtlfan
Jul 19, 2012 05:19 PM
Tars
Mar 23, 2011 06:51 PM
FTLOSM
Mar 9, 2010 04:49 PM
Montego2007
Dec 20, 2008 07:29 PM
MehlodyAura
Sep 22, 2006 02:47 PM
