1995 Mercury Sable Door Panel Removal
Old Jul 3, 2005 | 06:15 AM
jdawg38's Avatar
i want to upgrade my front speakers and i am having trouble with removing the door panels, any suggestions or schematics?? thanks jeff
Old Jul 16, 2005 | 11:18 PM
Sablefreak's Avatar
If you are careful you can remove it with a flat head screwdriver after unscrewing all the screws you can see on the door (check around the edges of the panel) then wedge the flathead screwdriver inbetween your door and the door panel and pry it off using the screwdriver and your fingers ( use your fingers as much as possible when you pry it up so you don't put all the force in a small concentraited areah and break your door panel) then you can remove the speaker brackets with the speakers attatched, they are 6 1/2", take out the screw holding the speakers to the brackets, and pry the speakers off (they are glued on) and simply screw the new ones on. You will need to splice thespeaker wires,and I don't know what the wiring code is, butyou can find it on the web. Line up the clips on the door panel with the appropriate holes and pop the panel back on and your set!
Old Jul 17, 2005 | 02:36 AM
jdawg38's Avatar
thanks i had purchased a door trim removal tool from crutchfield.com along with the new speakers, it was only 10 bucks but it was worth it, i only broke one clip while removing both doors. i got the new speakers in, which are a tight fit, could only get three screws in with each one but the speakers sound great. they were like 70 bucks and def make a huge difference
raw16057
Jan 23, 2015 04:51 AM
PB92
Oct 13, 2011 02:20 PM
knotdrummer88
Nov 7, 2010 10:19 AM
fiziksdrop180
Oct 18, 2010 11:50 PM
92Mercury
Sep 9, 2007 07:31 PM
