-   -   1996 sabe (https://www.mercuryforum.com/forum/sable-13/1996-sabe-130/)
tanya33 Mar 23, 2005 12:47 AM
i have a 96 sable here is the problem my temp gage rises when i am parked or idling when im driving its fine ive checked the fuse it was fine the fan is working anyone have any ideas
MercAdvisor Mar 23, 2005 12:53 AM
Is it a 3.0 12v or 24v. ?
tanya33 Mar 23, 2005 12:54 AM
i think its a 3.0
MercAdvisor Mar 23, 2005 12:55 AM
12 or 24 valve?
tanya33 Mar 23, 2005 01:07 AM
its a 12 valve
MercAdvisor Mar 23, 2005 01:09 AM
Ok, you may have a dirty radiator try cleaning the fins out with a hose. If that does not work the cooling system passages may be clogged and need to be professionally cleand and possibly a by pass hose will need to be added to the cooling system.
tanya33 Mar 23, 2005 01:14 AM
the radiater fluid is filthy so i guess that is the problem
MercAdvisor Mar 23, 2005 01:15 AM
I would definatly take it to a dealer and have it flushed and check for the possible by pass hose then
tanya33 Mar 23, 2005 01:16 AM
cant i flush it myself
MercAdvisor Mar 23, 2005 01:18 AM
You can do that but if the vehicle needs that by pass hose the concern will return after sometime.
