i dont think its the by pass hose i think its because its so durty its like a light brown with sh*t floating in it NOT OIL
yeah then just try the flush and see what happens |
May be the thermastat needs to be replaced? |
First of all, what fuse did you check? Second, the fan may be working but it is an electric fan. I would replace the coolant temp sensor. That will ensure the fan starts and stops at the proper temps. You could always run a straight wire to a toggle switch inside your car and when you come to alight or traffic you can turn the fan on and off yourself. Stay cool.
Are you still running into problems with this? If not, what was your final fix?
| All times are GMT -5. The time now is 09:28 AM. |
