2004 Sable Intermitant Start
Old Jun 23, 2008 | 05:36 PM
kc4rzw's Avatar
Have a 04 Sable that works great most of the time.
Sometimes after it has stopped (and getting more frequent)and the engine turned off, will refuse to start. The aux all work when the key is turned but turning the key to activate the ignition nothing happens.
After a few minutes, you turn the key again and it starts perfectly like nothing is wrong, and it runs great. This is baffling, need suggestions on how to track down the problem further. Could it be a switch or sensor, Have not figured out how to get it to start when it won''''t. Need any ideas?[img]smileys/smiley6.gif[/img]
Edited by: kc4rzw
Old Jun 29, 2008 | 03:59 AM
conan312's Avatar
does the starter click when it won''t start? is there a massive power draw when it is not starting? after long drives or short ones? let me know.
Old Jun 29, 2008 | 07:52 AM
kc4rzw's Avatar
The battery is up good, there is no click, the starter does not even try to turn over. After waiting for a while, put the key back in and it starts right up as if nothing was wrong.
I read on a ford forum that this problem has been known to be associated with the security key not being properly read by the security system in the car and so even though you have the right key if the security system does not think you have a security key it will not allow the starter to be engaged. This might be our problem but we are using factory keys and so not quite sure if this is our problem.
It is not a typical power to the starter problem, it may be a sensor, or a computer issue, or a security key problem. It does not happen every time the car is started. It will go for days starting just fine, and then right out of the blue it will not start. Put in the key and turn it and nothing, absolutely nothing happens. take the key out wait a while, yesterday the wait was just five minutes, put the key back in, and it starts right up like nothing was ever wrong. Any ideas?
Edited by: kc4rzw
Old Jul 2, 2008 | 09:00 PM
conan312's Avatar
I think you are on the right track w/the keys, but not sure how you should procede. Trying the spare key if there is one. No check engine or security lights on the dash, right?
Old Jul 3, 2008 | 07:25 AM
kc4rzw's Avatar
We got the problem solved is seems. The car got so bad that it was not starting about every other time. Took it to our mercury dealer who put it on a rack, got it to not start, tapped the starter motor and it started right up, they got it to not start and tapped the starter again and it started. We replaced the starter motor and everything seems to be working fine. Will comment again if we find that this did not really solve the problem.[img]smileys/smiley1.gif[/img]
Old Jul 4, 2008 | 09:40 AM
conan312's Avatar
Bum starter on an ''04. Hope it was not too pricey. Good luck.
FLionel
Oct 8, 2012 03:50 PM
ngnear
Feb 10, 2010 03:28 PM
MercuryWQQ
May 5, 2009 04:30 PM
longjt
Aug 14, 2007 08:31 PM
02trouble
Nov 29, 2006 09:05 PM
