93 SABLE WAGON lite problem
Old Apr 14, 2005 | 09:33 PM
stumped's Avatar
Have 1993 Sable wagon and the brake lights nor turn signals work.
I have checked fuse and bulbs. I have replaced brake switch.
tail lights work. Any suggestions would be appreciated.
Old Apr 14, 2005 | 09:51 PM
MercAdvisor's Avatar
You could have a bad multifunction switch which is your turnsignal swtich arm wiper assembly. However that is going to be a little bit of an expensive guess unless you can get one form a junk yard. You could also have a bad headlamp switch but if i was going to pick one of the 2 i would say multifunction. Edited by: MercAdvisor
Old Apr 15, 2005 | 10:41 AM
stumped's Avatar
I just realized that cruise control no longer works either.
Old Apr 19, 2005 | 05:19 PM
ugothim's Avatar
did you check the fuses under the hood and the ones inside the car ?
Old Apr 20, 2005 | 10:40 PM
Windzer's Avatar
turn signal switch shorted...
Old Apr 21, 2005 | 03:02 PM
stumped's Avatar
I can't stop looking at that avatar Windster.
Thanks for the info all I'll try turn signal switch.
leapin
Jul 3, 2007 06:35 PM
ajsjew
Apr 24, 2007 10:47 PM
bukukukoyak
Sep 23, 2006 01:30 AM
tiffany21074
May 10, 2006 03:52 PM
John Poole
Mar 28, 2006 11:50 PM
