-   -   AC not working - compressor clutch not activating (https://www.mercuryforum.com/forum/sable-13/ac-not-working-compressor-clutch-not-activating-6069/)
vtraudt May 27, 2012 09:03 AM
1999 Sable 3.0 DOHC
AC isn't working.
Charged system.
Compressor clutch not kicking in.
Should I first short the low pressure (small diameter line) sensor (not sure where it is)?
Is there a high pressure sensor also that may prevent the clutch to kick in (in case I either overcharged, or not enough)?
On some of my cars, there is an outside air temperature sensor; if the sensor reads below a certain temperature, the compressor does not kick in either. Is something like that on the car as well? If so, where is it located?
Note: outside temperature show temps way too low. Could a bad outside sensor cause the malfunction of the AC system?
