Bypass Hose
Old Oct 1, 2008 | 08:01 PM
Harvest Gold's Avatar
Found coolant leaking from the 2001 Sable. After much looking and troubleshooting, I found the hose connector cracked and is now completely broke at the upper radiator/bypass hose connection. According to the service dvd I have, it looks to be a time consuming change. It gives a basic p/n as 8548. Has anyone changed one? Is it a pain to do? Do I need to completely drain the antifreeze?
One other question, The manual says to use Motorcraft antifreeze VC-$-A. Is that the same as the green Prestone stuff. I have a couple bottles of their 50/50 mix.
As long as I need to change this I might as well change the low coolant sensor also. that light has been on for about a year now.
Thanks,
Old Oct 18, 2008 | 09:39 PM
BFM70's Avatar
According to my book the 01 Sable takes Motorcraft Premium Engine Coolant E2FZ-19549-AA, which will mix with the green prestone stuff you have just fine.
Not sure about that bypass hose. Looks like a PITA in my service manual too.
Old Oct 19, 2008 | 02:07 PM
Bypass hose assembly was pretty easy fix. Used the coolant I had in the garage and everything is just fine.
Old Oct 19, 2008 | 07:05 PM
BFM70's Avatar
Sounds good. Thanks for the update.[img]smileys/smiley1.gif[/img]
Edited by: BFM70
pdman
Dec 29, 2008 07:53 PM
caveman
Sep 2, 2008 12:06 AM
crazydoctorbob
Jul 20, 2007 01:00 AM
crazydoctorbob
Jul 20, 2007 12:54 AM
crazydoctorbob
Jun 25, 2007 10:07 AM
