a/c comes on with heat
Old Oct 21, 2009 | 04:54 PM
tthcare's Avatar
Default a/c comes on with heat
Hi everyone new here,
I have a 99 sable that the a/c comes on with the heat. When I turn the control to defrost, floor, defrost/floor etc. with the **** turned to hot the a/c compressor and radiator fan turns on. If I turn the control to the cool side everything cools down correctly. But if I turn it back to hot it blows out luck warm air because both the a/c and heat are working. If I turn it to just the vent position and hot I get good warm air. So my question is why is the a/c coming on with the heat. I can here the door open and close under the dash so that seems to be working.
I did just change the metal line under the hood next to the fire wall that connects to the heater core they had a hole through them. Those lines are nice and hot so the heater core isn't plugged. I don't know if this was already there because it's my wifes car and I don't drive it all the time. Any help would be appreciated.
Tony
Old Oct 21, 2009 | 09:04 PM
The AC compressor should be on for defrost and mix but off for floor. There is probably a relay sticking or some such nonsense. Do you have the manual temp system or the automatic temp system (sounds like you have the manual one). I'm not sure how the controls tell the compressor to engage or not for a certain setting, but it sounds like it's not working right on the heat side of things.
Old Oct 22, 2009 | 06:17 AM
tthcare's Avatar
I believe it's the manual control, has three *****.
Old Nov 21, 2009 | 05:15 AM
bigjoe09's Avatar
is he right or is he right
Old Nov 21, 2009 | 08:00 AM
tthcare's Avatar
I do have the manual controls. I haven't drove the car since I replaced the heater hoses. The wife tells me everything seems to be working correctly. I guess I will wait for colder weather.
rocasan
Oct 23, 2012 01:36 PM
rocasan
Oct 23, 2012 01:12 PM
Jrock
Aug 19, 2009 08:11 AM
cougar01
Oct 15, 2006 07:13 PM
soldout162000
Jun 30, 2005 03:06 PM
