CEL after cleaning injectors
Car was running great, no problems. Got a routine oil change and was talked into cleaning the fuel injectors. After about 5 miles from leaving the lube shop, my Check Engine Light comes on. Man, why didn't I leave well enough alone.......
I have to believe its because of the injector cleaning. I checked for loose vacuum hoses...etc, but nothing found. What the heck? Anyone run into same issue after this procedure, and what did you do to correct it?
Thanks.
Thanks.
