coolant type
Here's a link:
http://www.motorcraft.com/products.do?item=6
Check the owners manualfor specification.May need a flush to restore to correct spec.
Dexcool is not made for use in your cooling system and will actually cause corrosion and even cause engine damage. Use good old green, and if you live in a cold climate don't ever use straight anti-freeze because it will freeze faster than a 50/50 mix.
