low oil pressure of 2004 sable
Old May 3, 2009 | 10:36 PM
MercuryWQQ's Avatar
Default low oil pressure of 2004 sable
My car is 2004 mercury sable. It has a problem.
When I trun the key to "on" , the information center shown that "low oil pressure", But after start the car, the "low oil pressure" disappear.
I check the engine oil level is ok!
What cause the problem? and dose this problem could cause the damage of engine?
Thanks!
Old May 4, 2009 | 08:03 AM
there's no problem. the oil pump only runs when the engine runs so without the engine running, there's no oil pressure.
Old May 5, 2009 | 03:28 PM
MercuryWQQ's Avatar
Thanks.
But someon said that the oil pump has problem, and the other one said that I need to reset the information center.
How do I do?
Old May 5, 2009 | 04:30 PM
oil pump is mechanical... it wont work unless it has the engine running. the lights usually turn on as a way to let you know the bulbs are working in the dash. i am sure there are a couple other lights that come on when the car is off but key is on too.
bittersweetiris
Feb 18, 2014 08:37 AM
mrrotary
Jul 7, 2012 07:26 PM
ptrama
Jul 1, 2006 11:58 PM
steve
Jan 20, 2006 12:01 AM
