Overdrive Highway RPM's
Old Dec 10, 2019 | 03:27 PM
fcasontoo's Avatar
Default Overdrive Highway RPM's
Just picked up 2000 Sable from father-in-law, drove it home from Dallas to Houston. At highway speeds, 70-75, rpm's are at 2500-3000 as if transmission is not shifting into OD. Is this normal rpm range for the 24V v-6 engine and transmission?
Old Dec 10, 2019 | 03:37 PM
fcasontoo's Avatar
It has 69k miles on it. It also is howling very loud and can feel it in the gas pedal. Is this going to be a wheel bearing, cv shaft or transmission issue?
Old Dec 11, 2019 | 03:50 AM
raski's Avatar
There should be an O/D on-off switch on the gearshift **** which you can toggle and see if the RPM changes.
Wheel bearings will howl and change pitch or dissapear as you corner or taking turns, changing the load on the bearing. The CV joints will make a clicking noise, changing as you do cornering.
blt1952
Feb 7, 2017 09:17 PM
bigblock79
Mar 7, 2011 05:13 AM
desabler
Jun 7, 2010 09:55 PM
propack
Aug 1, 2009 10:31 PM
schluppy
Nov 9, 2005 03:00 PM
