Radio Problems
Old May 10, 2006 | 07:56 PM
mjrehrig's Avatar
I recently purchased a used 1994 Mercury Sable. So far, the radio has never worked right. It randomly changes stations and sometimes the display only says TELE. While it says TELE, the radio does not play and you can not change it. The only way to get it off of TELE is to turn off the car and then on again. Any help? Also my remote control buttons for the radio do not work (the ones on the dash, on the right side of the steering wheel) is there a fuse that I have to replace or something?
Thanks!
Old May 13, 2006 | 01:01 PM
Lenny's Avatar
tele is the hands free telephone option on the car. It sounds like you have stuck/worn out contacts on the unit.
Old May 20, 2006 | 01:46 PM
mjrehrig's Avatar
Thanks for the response, Lenny. Is there any way to fix this, or am I stuck with getting a new radio? Or is there a way to get it off of TELE, because when that comes on, it refuses to go away until I turn off, then start the car again.
Thank you
Old May 22, 2006 | 11:45 AM
Lenny's Avatar
It is usually less expensive to purchase an aftermarket stereo of your choice. The stock stereo can be repaired,but usually at a higher cost than aftermarket.
99mercwagon
Aug 8, 2014 09:06 AM
fif4evr
Sep 21, 2012 09:27 PM
Godslay3r
Sep 28, 2011 05:54 PM
gminnow
Feb 6, 2006 10:14 PM
PiTcReWfLuNkY
Jul 16, 2005 10:32 AM
