Rear brake line shape
This is the only car I evey had with front wheel drive I need to change the front springs and shocks where is a good place to jack it up and place jack stands to work on these parts. ts a 2000 Sable,Sorry about the stuipd question.
PS does it have a cross member
look for a cross member (not radiator support) in front if not either side at jacking station (indent in pinch weld at bottom of body) you should see frame around engine area place stands there or at a frame ( box steel) to support car. Do one side at a time use good spring compressor and be careful!!! BE SAFE !!
PS I forgot to thank you for your service and have a Merry Christmas.
Anytime, don't forget to check alignment after. I make a mark in strut tower at the bolts so I can get close to original if posible so alignment is not to far out of wack!
MERRY CHRISMAS AND THANK YOU BROTHER!!!
Thanks. are you talking about the lower or the up on top?
At the top under the hood I make a little scracth mark in the paint to align the bolts as close as possible to original. I am not sure if the holes for the bolts on top are slotted ( for alignment) if they are this is for caster/camber wheel alignment. You should have an alignment after the strut replacment anyway. it's worth the money!!!!
