Sable will not turnover
At 10 years of age both are a possibility. It could also be corroded connections or battery cables. Best way to isolate is to do voltage checks at each connection & also voltage drop test at each connection. You should be able to hear the solenoid click. If not check to see it is getting power to it from the key.
If no power to it, then ignition switch or neutral switch. Speaking of neutral switch, is the transmission in park or neutral?
