If you want to put a SHo motor in it, you will have to get the complete setup in cludng the suspension. then you will have to lift the sable in the air and drop it over the entire SHo setup. you will need a lift for this. otherwise if you use a enging hoist you will need to modify and fabricate a new firewall and radiator core support to fit the new motor from the top and this will allow you to use the current suespension
