turn signals
Old Feb 25, 2006 | 08:05 PM
gl8c1er13's Avatar
I resently bought a 98 sable and it does not have an owners manual how doe i remove the head light assemble to change the turn signal bulbs as well as the halogens
Old Mar 1, 2006 | 06:49 PM
conan312's Avatar
the turn signals are not in the same assembly as the headlights, just the parking lights. the turn signals are in the middle on each side of the grill. the halogens unplug from the back of the headlight assembly, then unplug from the wire. when replacing the halogens remember NOT to touch the glass portion of the unit. the natural oils, plus whatever else is on your fingers can damage the bulb. good luck.
Old Mar 20, 2006 | 07:37 PM
gl8c1er13's Avatar
Thanks but i'm sorry what i meant was the park lamps.
Old Mar 29, 2006 | 07:01 PM
conan312's Avatar
ok the turn signals are in the grill. the parking lamps reside inside the headlight housing. all unplug from the rear under the hood. check for screws on the front of the turn signals just in case, for the ones on the front fender have one phillip's head screw to remove the bulb. good luck.
Old Apr 24, 2006 | 02:59 PM
conan312's Avatar
I recant. You have a 1998 and the front turn signals have one phillips screw accessable through the grill. I think both park and turn are the same bulb 3457NA(NA means amber)
kim4law
Jan 4, 2013 07:52 PM
Hetron
Mar 6, 2012 09:36 PM
Cathy Kirkes
Jul 22, 2007 10:15 PM
Cathy Kirkes
Apr 19, 2007 08:00 AM
Cathy Kirkes
Apr 14, 2007 11:34 PM
