-   Sights N Sounds (https://www.mercuryforum.com/forum/sights-n-sounds-11/)
-   -   Sound systems... Do you have one? (https://www.mercuryforum.com/forum/sights-n-sounds-11/sound-systems-do-you-have-one-3291/)
kwolfeman91 Sep 24, 2009 11:06 AM
yeh... it worked on my 93..
slymer Sep 24, 2009 12:39 PM
worked on my 88 too.
kwolfeman91 Sep 24, 2009 05:34 PM
yeh... he should have no problems with it..
MJB DIGITAL Sep 30, 2009 10:45 AM
my sound system? hmm
well the guy let me have the stereo head that was in it because 'it was broken'. So I pulled it out and borrowed a fuse from the fusebox in the dash...voila.
The back speakers work but not the front.
There is some kind of tiny amp in the trunk I know nothing about.
bump? more like fart. haha
kwolfeman91 Sep 30, 2009 12:44 PM
If its a small amp it might be a factory amp... factory amps come on a few cars stock...
kwolfeman91 Oct 16, 2009 09:57 AM
i have came to the conclusion that my 1 class d amp is not enough for me so im thinking bout purchasin a new one as well...
87_Crown_Vic Oct 30, 2009 07:31 PM
you guys ran your wires too far... i ran mine thru where the antenna goes thru firewall on passenger side under the blower motor and feeds into just above where passenger feet are and straight back along floor trim to the trunk. the RCAs i ran down center of car after pulling passenger seat to hide it all under the carpet. wiring on outside of car is bad idea with corrosion ith trying to power your stuff in the trunk.
slymer Oct 31, 2009 12:02 PM
mine was run almost the same route... cept I went through the door to body flex hose and re-sealed it with black silicon after. Since my amp is under the passenger seat, I ran all the power to that point and then ran the speaker wires down the side molding under the back seat and into the trunk behind the carboard/carpet to the speakers.
