3.0 timing belt question(s)
Old Jul 11, 2009 | 02:16 PM
sackman9975's Avatar
Default 3.0 timing belt question(s)
Ok, I got a freebie 94 villager. Doesn't run. Came with no battery. I put a battery in today, cranked it, no fire. Pulled the distributor cap and the distributor is not turning, but it's sending spark through the coil wire even though it's not cranking. So this tells me that the timing belt is broke or missing teeth. My main question is, is this a motor where the valves are gonna bend if the belt snaps? If so, I probably ain't gonna mess with it. But if it's not, then it's a money maker for me and I'll fix it. Thanks for any replys.
Old Jul 11, 2009 | 05:26 PM
not sure if it's a given that there will be damage to the valves. (of course you could always take the heads off and see... I've heard that with the 3.0 there is enough clearance, but I could be mixed up. there's other people on here who should know for sure.) since you're looking at taking the timing cover off anyhow, you could take it off and rotate the cam to see if it will make a full rotation or two. that might mean that there's nothing impeding the valves and they're fine (turn the crank to top dead center as you try) if you get any stoppage, then that means there's probably damage inside. Or just wait for the guys who know for sure to come on and tell ya.
Old Jul 12, 2009 | 09:05 AM
Ok well I guess I'm gonna find out myself. I've done some searching, and asking on another forum (www.fullsizebronco.com) and I'm getting info that its not an interference engine and that it is an interference engine. Well I'll just change the $20 belt out and see. Its either gonna run or backfire like a son-of-a-gun.
Old Jul 12, 2009 | 03:38 PM
true... good luck. Let us know how it turns out.
Old Jul 14, 2009 | 10:42 PM
conan312's Avatar
If it is the Nissan/Mercury shared 3.0L then it is a non-interference engine. You should be good to go.
Old Jul 15, 2009 | 11:19 AM
That's what I want to hear.
I haven't got to it yet. Hopefully this weekend I'll get to it. I won't let this thread die without closure.
Old Jul 15, 2009 | 09:31 PM
Well the motor is no good. Tore it down, and went to position the cams, and the rear cam won't budge. That's why the belt went. Going to the bone yard............
Old Jul 16, 2009 | 03:30 PM
Sandra9810's Avatar
Wish you were in Florida... I could use a spare car for some parts. Really need to get new front seats, they're totally beat up.
We've had just about everything besides the engine and the AC replaced.... it now needs it's third transmission.
dwendt44
May 11, 2012 06:29 PM
jakewayne
Nov 19, 2010 12:17 AM
mrutah12
Jun 11, 2009 02:56 AM
fud2468
Feb 13, 2008 12:14 PM
pandora373
Feb 3, 2006 03:40 PM
