Strange Noise in 97 Villager
Old Jul 13, 2008 | 11:17 AM
kbsmom's Avatar
My 1997 Mercury Villager is making a strange noise. When I put the brake on, it goes away. Any ideas?????
Old Aug 2, 2008 | 03:42 AM
conan312's Avatar
I''m going with a wear indicator on the brake pad. Check the front pads for wear and possible rotor damage.
Old Aug 13, 2008 | 02:22 PM
jason sereiko's Avatar
most likely you have rust from the rotor that broke off and is being dragged on the pad and rotor. this will cause the noise goes away when you hit the brakes. clean the rotor sides with as wire brush, not thepart that the brakes go on . th edges flake off rust and get stuck between the pads.
Old Aug 13, 2008 | 06:09 PM
conan312's Avatar
If you have brake noise, check the rotors and the pads for wear, or drums and shoes for the same. If rust was capable of making a strange noise by getting in between a pad and a rotor,(not happening) it would be obliterated immediatly. Next time just ask kbsmom if a solution was found to the problem when you feel like throwing in your rusty 2 cents. You are a posting ***** Jason, who has no idea of proper forum etiquette. [img]smileys/smiley5.gif[/img]
Old Aug 13, 2008 | 06:28 PM
WOW!
how old are you? what is wrong with you.
please let this be an example to not take the advice fromm a psyco
Old Aug 13, 2008 | 06:30 PM
just check the brakes and see if it is the pads or rust. does it matter who is right or wrong?
please just ignore conan. he has some mental problems and low self image of him self
LuiV060807
Mar 7, 2011 03:23 PM
JerseyTrueBlue
Feb 24, 2010 10:16 AM
cdjgmom
Jun 24, 2009 04:35 PM
Mercurytaxiguy
Dec 6, 2008 06:30 AM
dmddfkc
Aug 7, 2007 10:11 AM
