1996 sabe
Old Mar 23, 2005 | 12:47 AM
tanya33's Avatar
i have a 96 sable here is the problem my temp gage rises when i am parked or idling when im driving its fine ive checked the fuse it was fine the fan is working anyone have any ideas
Old Mar 23, 2005 | 12:53 AM
Is it a 3.0 12v or 24v. ?
Old Mar 23, 2005 | 12:54 AM
tanya33's Avatar
i think its a 3.0
Old Mar 23, 2005 | 12:55 AM
12 or 24 valve?
Old Mar 23, 2005 | 01:07 AM
tanya33's Avatar
its a 12 valve
Old Mar 23, 2005 | 01:09 AM
Ok, you may have a dirty radiator try cleaning the fins out with a hose. If that does not work the cooling system passages may be clogged and need to be professionally cleand and possibly a by pass hose will need to be added to the cooling system.
Old Mar 23, 2005 | 01:14 AM
tanya33's Avatar
the radiater fluid is filthy so i guess that is the problem
Old Mar 23, 2005 | 01:15 AM
I would definatly take it to a dealer and have it flushed and check for the possible by pass hose then
Old Mar 23, 2005 | 01:16 AM
tanya33's Avatar
cant i flush it myself
Old Mar 23, 2005 | 01:18 AM
You can do that but if the vehicle needs that by pass hose the concern will return after sometime.
