Capri Discuss the Mercury Capri here...
’’91 Capri Cig. Lighter fuse location
Old Dec 5, 2008 | 01:58 PM
PCFree50's Avatar
Trying to find the cig. lighter fuse on my ''91 Capri. Checked all the fuses under the dash above my left foot but all check OK.
Help?
Old Dec 5, 2008 | 05:41 PM
are you sure it''s a fuse problem? have you checked the wiring? Is the cig lighter rusted/corroded?
Old Dec 8, 2008 | 06:38 AM
PCFree50's Avatar
The lighter never gets used. I wanted to plug in an inverter to power a laptop. It is also tied to the power locks. There is no lock switch inside. When you unlock or lock one lock, the other lock would actuate. Neither has worked since the lighter stopped working so I suppose they share the same circut.
Old Dec 8, 2008 | 12:35 PM
or they share the same ground to the chassis and that bolt has come loose. if all the fuses check out, you may have to do some wire chasing.
Old Dec 8, 2008 | 01:49 PM
PCFree50's Avatar
Good point on the ground. I''ll check.
Thanks
frtillman
Jul 5, 2010 01:01 PM
ref2coach
Dec 9, 2009 09:31 PM
mabney007
Feb 12, 2009 03:26 PM
Flominator
Jul 22, 2006 09:32 AM
jollyjohnj
Feb 21, 2006 11:04 AM
