Capri Discuss the Mercury Capri here...
hard starting
Old Sep 24, 2011 | 02:41 PM
white93's Avatar
Default hard starting
I have a 93 capri non turbo I bought for my Grandaughter and am in the process of making it ready for her. I have encountered a problem. When it is damp outside or has rained the car is extremely difficult to start and has a hard time running once started. I started looking at plugs first and found one plug closest to distributor the rubber valve cover seal is leaking. I pulled a plug wire off one cylinder and the wire came apart. Needs a rotor for sure. Distributor pickup is in what condition I dont know. I can look at it and I have no idea what it should be like. I took the valve cover off and inside it isnt all that bad dirty. So I am thinking it must be an electrical starting issue. I have taken the MAF off and am not that upset about taking anything else off that may have a part in hard starting. During dry weather it starts and runs fine. Its just that I am not sure what I need to replace. Should I buy Mazda parts or ask for Capri parts . Just and expense issue question. But I need some assistance in trying to figure this out so I do it once and be done with it. Any help is most appreciated and I thank you ahead of time.
Old Oct 15, 2011 | 09:10 AM
Slimbob's Avatar
If you can put it in the garage or wait til after dark and it is acting up you can look for arching under the hood. Maybe even use a spray bottle and spray water on the coils, distributor, wires and plugs to see if it makes it act up.
Good Luck,
Slimbob
cinquea
Jul 13, 2012 10:49 AM
olds97_lss
Jun 13, 2008 03:28 PM
jason sereiko
May 22, 2008 09:36 PM
brickman
Aug 6, 2006 05:34 PM
fooswinger
Feb 26, 2006 10:25 PM
