Interior leak
Old Feb 1, 2005 | 06:27 PM
tigerfan31's Avatar
I own a 1996 Grand Marquis.
Just recently I have noticed a leak on the front drivers side floor board.
It seems to only get saturated when it rains, and it rains alot in La.
Is there anything I should be looking for on the inside of my car. I have looked right behind the emergency brake, but I didn't feel any moisture.
Any solutions?
Thanks
Old Feb 2, 2005 | 01:15 AM
Does the vehicle have a moonroof or sunroof?
Old Feb 2, 2005 | 11:28 AM
tigerfan31's Avatar
No, my Mercury does not have a moon/sun roof. Any suggestions?
Old Feb 3, 2005 | 01:23 AM
I would run a hose at the bottom of your windshield and along your firewall then those cars have had problems with seals around the openings through the firewall letting water in but it usally hapeens on the pass side but it could be travling
Old Oct 29, 2006 | 08:52 PM
jbrocco's Avatar
I also have a 96 Grand Marquis...but my leak is in the passanger side front and rear foot wells. I know it's not a heater core or sunroof leak. It happems everytime it rains. The door weatherstrips look fine also. Any help would be greatly appreciated.
Old Nov 27, 2006 | 04:35 PM
jbrocco's Avatar
I Have found out why the keak is happening on the drivers side...the water that falls from the windsheild sits and raises in the engine compartment just below the rubber grommet for the hood release...when the water raises up, it seeps into the car through the grommet....hope this can help someone...[img]smileys/smiley17.gif[/img]
Old Jan 25, 2007 | 11:39 PM
thecowboy71's Avatar
the grand marquis a known for leaks in the fire wall round where the wipers are can usually fix it with toob of silicone ....hope this helps
Old Feb 10, 2007 | 08:29 PM
tomcat's Avatar
My Sable has also suffered a wet passenger side floor. I've read on the Taurus forum about a "rainhat" mod to prevent this water leak, but I don't know anything about it. If anyone can help, let us know.
TC
Old Sep 30, 2010 | 05:01 PM
rjohnson67's Avatar
I had a leak in the firewall of my grand marquis, fixed it with silicone.
Old Jul 26, 2017 | 06:49 AM
TNMtnBob's Avatar
Immediately to the right of the power brake unit there is a vertical rectangular wiring block with two bolts holding it to the firewall. i tightened both of those bolts and no more leak.
paniro187
Jun 18, 2007 10:34 PM
h0l0caust
Nov 8, 2006 07:44 PM
Pako
May 11, 2006 07:55 PM
carolinatexpro
Dec 22, 2005 11:33 AM
roberts99
Dec 21, 2005 01:27 AM
