Capri Discuss the Mercury Capri here...
1994 N/A no start...
Old Oct 31, 2019 | 01:36 AM
ptt12's Avatar
Default 1994 N/A no start...
The car has been sitting undriven for a year but was started intermittantly.. Then recently it would just crank and not start. I had been putting new parts on it off and on. New power steering pump. New MAF Sensor. New Sparkplugs and Wires. New Air Filter. New Coil. New Fuel Filter. Just recently with the crank only issue I noticed there was no fuel getting to the Fuel Filter on the firewall. I pulled the backseat and removed the Fuel Pump which was very rusty and crusty. Replaced the Fuel Pump. The Fuel Tank was around 3/4ths full. Still no fuel to the Fuel Filter. I have determined the car has spark. I have yet to locate the Fuel Pump Relay behind the center console tower. I have not found any blown fuses. Any thoughts or ideas appreciated. Thanks!
Old Jun 9, 2021 | 04:34 AM
Josephmorrison's Avatar
Check in the trunk for a shut off switch. It it has one it will be on the driver side quarter panel. Ive accually seen them trigger off before.. use some sea foam to if it's been sitting. Mine sat for 8 months I used that now it runs great.
ptt12
Oct 31, 2019 01:20 AM
radman
Apr 26, 2012 07:13 PM
srm12711
Jun 10, 2009 09:00 PM
wizkid
Sep 15, 2008 10:50 PM
scruggsy
Jul 20, 2005 10:31 PM
