'93 mercury capri issues
Hi all, I just recently joined this list because I bought a '93 non-turbo Capri in July and I have been experiencing some issues getting it back into great running condition. It has 67,000 miles on it so far. The engine is in excellent condition but I am simply not sure what the private dealer did to the distributor and the wires surrounding it. It looks like these wires have been cut and then re-wired. I have taken it in to two mechanics and they have not been able to diagnose the underlying issues. I'm not sure what could be causing the following problems.
Here are the symptoms so far:
A hard start-up that takes several cranks, but this only occurs when the engine has cooled down. When the engine is warm, it starts fine.
A rough idling where the rpm goes up and down and almost stalls at times. This occurs when the engine is warm.
Work that has been done:
Distributor rotor and cap replaced
spark plugs and plug wires replaced
fuel filter replaced
idle air intake adjusted higher
water pump replaced
transmission fluid flushed and changed
Let me know your thoughts. I love this car and I just want to ge
water pump replaced
