ignition shutdown
Old Aug 29, 2007 | 12:43 PM
Secretary's Avatar
I HAVE A 1994 COUGAR. WHILE DRIVEING, IT JUST SHUT DOWN. WITH NEW PARTS, IT STILL WON'T START UP. MECHANICS CAN'T FIND A PROBLEM, BUT WE KNOW THERE IS ONE. PLEASE HELP ME WITH THIS PROBLEM.
THANKS,
WILLIEEdited by: Secretary
Old Sep 20, 2007 | 12:04 AM
cougarowner's Avatar
hm...whenever you start it up...if you keep it in idle for a while does it shut down? or just shuts down right away???
Old Sep 21, 2007 | 11:27 AM
Secretary's Avatar
I am a Cougar owner, I bought it new in 1994. However, it started shutting down while driving alone. The last time it shut down, I had driven about nine miles on straight high way and it just shut down. All the lights in the dash came on, but would not restart. To this day it cranked once since then.
Old Sep 21, 2007 | 11:52 AM
hm...wow...it might be either the alternator, starter, connection to the starter, or somethin like that. one time i had problems gettin mine started up, like it would start up but then try to shut down, and with that problem my Vacume hose needed replaced. so you might want to even get that checked.
Old Oct 16, 2007 | 07:53 PM
conan312's Avatar
It sounds like your crank sensor is faulty if the car shut down at highway speeds.See if you or someone who understands the phrase, " excite the solenoid " can give that a try and see what happens. It means to touch the two poles on the solenoid or starter together. That should narrow it down.
forkliftrman
Mar 4, 2008 10:12 AM
Enforcer
Feb 24, 2006 10:09 AM
SableCat
Sep 10, 2005 08:12 PM
sinned
Aug 13, 2005 11:17 AM
teskey3
Jan 23, 2005 02:12 PM
