1991 mercury capri starting problem i cant figure out
Old Sep 11, 2013 | 09:07 PM
grimmallan's Avatar
Default 1991 mercury capri starting problem i cant figure out
my 1991 mercury capri non turbo has 104k on it. at first it would start to pop off then die and crank without popping off again. then you could shut it off and wait for 5 minutes then do it all over again. by passed injector shut off cause it was getting constant spark, and with the injector shut off still did same thing. would start to pop off then die. replaced fuel pump because it was weak. now you can hear the fuel pump run. if you let it sit a bit then try to start it it will pop off then die and if you just keep doing that for 10 times in a row without letting it sit, it will then after about the 1oth time will then start, idle to about 1500 rpm then die. then it will just keep doing that. if you hit the gas it will do a sharp rev then die at 1300. then if you let it sit for about 5 minutes you then all over again have to let it pop off about 10 times before it will start revving then dying. fuel pump stays on whole time it starts dying. so its not dropping fuel and not dropping spark. because pulled a plug and checked. any ideas?????????
Old Sep 12, 2013 | 08:08 PM
grimmallan's Avatar
I just tonight ran it for 5 minutes off a can of starting fluid. the fuel high pressure line does not have high pressure in it but the fuel return line sprys out gas when disconnected. and the hose does pump fuel back to gas tank through the fuel return line. I tried pinching my fuel return line off at the injector rai and that did not help. sometimes it just cranks and cranks and other times it will try to pop off, rev, then die. and just pops off sporadically but you can get it to run and run all you want spraying starting fluid into throttle body. does ANYONE have any ideas yet?? just ideas of what to try will help. I am a foreign car guy. got no clue what could be causing it in this car. I was told either the computer or the ckfp -crank shaft position sensor- built into the distributor. but it seems either the fuel return regulator not working and causing proper vacuum or its something else. I dunno. should not the high pressure line to the injector rail have high pressure// not the return line??
moosenbabe
Mar 7, 2012 07:03 PM
Stealthlead
Aug 3, 2009 11:55 AM
marcia
Jun 14, 2009 12:04 PM
klzeprobe83
Feb 29, 2008 11:18 PM
MercAdvisor
Apr 18, 2006 06:25 PM
