2002 Fuel Filter
Old Aug 19, 2018 | 04:20 PM
Kdhicks's Avatar
Default 2002 Fuel Filter
I'm trying to get the fuel filter off my 02 GM. Do I need to buy a disconnect tool to do so ? Thanks
Old Aug 20, 2018 | 10:07 AM
The correct fuel filter for your 2002 Grand Marquis is:
Motorcraft # FG1114
RockAuto.com has them at a good price.
You will not need any special tools to remove and replace the fuel filter.
Two (2) new plastic clips will come with the filter.
Pry out the old clips with a screwdriver -- remove the old filter.-- check the flow direction, and install the new filter -- install the new plastic clips.
Be sure to bleed the fuel pressure down before starting work on the fuel system.
Gasoline is VERY dangerous due to the likely chance of fire and/or explosion.
Work safely -- the life you save may owe me money !!
raski
Dec 17, 2018 09:21 AM
radman
Apr 26, 2012 07:13 PM
wizkid
Sep 15, 2008 10:50 PM
mercury650
Aug 19, 2007 12:32 PM
sillyburt
Apr 16, 2007 02:59 AM
