Clicking noise from rear wheel
Old Aug 17, 2011 | 07:55 AM
mstorrs's Avatar
Default Clicking noise from rear wheel
2004 mercury mountaineer makes clicking noise when you slow down or make a turn at a slow speed. I have heard it on the explorer also. Read that it could be the parking brake shoes inside the rotor. I have disc brakes all the way around. Could it be possible to have brake shoes too. If anyone had this problem please let me know what this could be. Thanks in advance.
Old Sep 12, 2011 | 12:38 PM
jakesulivan's Avatar
Did you tried to find out exactly from where the sound was coming? It can come from engine bay or from near the wheels also?
Old Mar 20, 2012 | 11:48 PM
fordvictora1956's Avatar
remember even tho you see thru the wheels a rotor on all four corners that dont mean you dont have brake shoes, they use shoes for the emergency brakes and the wheels stop under pad and rotors.
Old Apr 19, 2012 | 05:41 PM
radman's Avatar
Default Rear Brake Shoes
Your car has brake shoes that are used as parking brakes inside the rear rotors. They are bonded to metal with a glue type material. In northern areas of the country where salt is used on the highways in winter these brake assemblies get very rusty and the rust will cause the shoe lining to come off of the metal backing. It is possible for the lining to become lodged between the brake adjuster parts and the internal drum so tightly that it can lock the rear wheel causing a skid. Ask me how I know.
dpty22
Aug 22, 2014 05:03 PM
mstorrs
Dec 27, 2010 01:08 PM
mstorrs
Jul 14, 2010 06:24 PM
crazycraig68
Sep 21, 2009 01:01 PM
281_Law
Apr 21, 2009 12:23 PM
