ENGINE KNOCK WHEN ACCELERATING
Old Nov 5, 2007 | 05:31 PM
B63XL's Avatar
2004 GRAND MARQUIS, WHEN I ACCELERATE I GET A KNOCKING SOUND.
DOES ANYONE KNOW WHAT THE PROBABLE CAUSES ARE??
Old Nov 7, 2007 | 09:38 PM
92mercmadman's Avatar
upper or lower of the motor??
Most likely a rod knock, the original Mercury 4.6 in my grand marquis had a hard rod knock, the idiot before me ran er low on oil for about 300 miles. Not good. [img]smileys/smiley19.gif[/img]
did you run it low on oil, go way over on a oil change??
reply ill help ya with this...
but if she does end up needing a new motor get the interceptor motor(NO GOVERNER)thats what i did in mine...
let me know!!
-CheersEdited by: 92mercmadman
Old Jan 17, 2008 | 05:55 PM
could be pinging type knock you have which would be timing. could be what 92mercmadman said also. try 10w30 or 10w40 with some Lucas or something and see if i helps.
Old Jan 26, 2008 | 12:47 AM
conan312's Avatar
Only under acceleration? What about at idle? Is it definatley a knock and not pinging? How many miles on the car? Let me know.
Old Feb 13, 2008 | 03:32 PM
blutooth's Avatar
Try a higher octane gas (93) and see if the knock goes away.< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-45";
urchinTracker();
Old Feb 13, 2008 | 10:59 PM
must have solved problem and not let us known, or engine died in blazing fire going out as a fighting panther
HughJass
Aug 4, 2019 01:32 PM
gl2001_cougar
Jul 7, 2009 05:00 PM
ROBBINFOOLS
Nov 12, 2008 11:23 PM
Meilink
Jul 13, 2008 09:45 PM
wkroll
Oct 5, 2006 11:12 PM
