Help with 95 Grand Marquis
Old Oct 12, 2015 | 05:32 PM
Tim Hueber's Avatar
Default Help with 95 Grand Marquis
My 95 Grand Marquis has had an intermediate problem sometimes it just dies while driving and then wont start turns over if u wait a while u might get lucky and it may start we have replaced the coil sensor the crank sensor and relays problem still exists and out of 7 mechanics locally can't figure it out any help would be greatly appreciated ty ....
Old Oct 13, 2015 | 11:29 AM
padroo's Avatar
Is it getting fuel? I always troubleshoot starting problems with starting fluid. If it starts and then dies again it is fuel related. If nothing happens I look elsewhere.
Old Mar 14, 2017 | 03:00 PM
If your '95 Merc dies out while you're driving down the road, the problem is electrical, probably a bad alternator. Have the alternator tested and the battery charged up at about 6-10 amps per hour.
The Bosch AL7537N @ 130 Amps is the correct alternator for your '95 GM.
Another cause of this problem is failing ignition coil(s) -- there are two (2) 4-post coils on your 4.6 Litre engine. Correct coil resistance is 14-15 Ohms, measued across the 2 closest posts on each side of the coil.
If you have the factory ignition wires, replace them with Bosch Premium Mag-Core wires.
Recommended spark plugs for your engine = Bosch #9605 Iridium.
Good Luck !!
Old Dec 16, 2018 | 12:35 AM
ru4mercurygm's Avatar
Thumbs up
Good Luck !!
would you recommend same plugs and wires for my 2005 MGM Ultimate Edition???????
Bought my 2005 MGM with only 13,000 miles on it for $6,000.
The tires were original made in 2004. Tire guy recommended immediately replace with new tires.
The engine compartment is still like it came off the showroom floor.
Not sure if I should have all hoses wires and plugs replaced with new.... everything under the hood looks brand new.
Sorry for the thread highjack...... but thanks for any information.
Old Dec 16, 2018 | 11:23 AM
Your 2005 Marquis has some engine changes from the 1995 --
Spark Plugs = Bosch # 9606 Double Iridium Type.-- Your original spark plugs should last until 75,000 - 100,000 miles.
There are no Plug Wires on the 2005 -- Each Spark Plug has it's own coil..
I wouldn't advise replacing all hoses, unless they are visibly cracked or swollen.
Those "Tire Guys" are notoriously ignorant about passenger car tires and tire maintenance.
Each person's circumstances are different, as in location, climate, speed, and load.
Best for me =
Goodyear Assurance ComforTread All Season. - 98T
Load Range "T"
Speed = 118 mph
Long distance, high-speeds, desert heat, mountain driving, all weather.
The Goodyear tires give me excellent comfort, handling, and vehicle control, as well as a smooth, quiet ride.
MOST IMPORTANT -- Get a "Computer Alignment" that gives a "print-out" of the before-and-after info.
If they don't offer a computer alignment with print-outs, GO SOMEPLACE ELSE !!
Terry
Feb 17, 2019 11:26 AM
95 MERC
Sep 1, 2017 11:41 AM
Susan
Sep 8, 2009 06:12 PM
PlaskiGolfer09
Dec 4, 2008 09:34 PM
lil_brat_jones
Jul 11, 2006 02:19 AM
