interor lights stay on
Old Jun 4, 2009 | 07:33 PM
86 vic's Avatar
Default interor lights stay on
ok i got a 86 crown vic and the interior lights stay on light switch does nothing to the interior lights but i still got function to the head lights so if anyone can help i very muck appriciate it
Old Jun 5, 2009 | 07:13 PM
make sure the switches that control lights to each door are adjusted right. they are push buttons and from years of opening and closing the switches get pushed in and dont realize the doors are shut so switch remains on. the swithces pop out and can be turned out. might have to go to junkyard for parts since it is made of plastic. i need to get some for 2 of the cars here since they did the same thing and i unplugged them till i get switches replaced. probably wouldnt hurt my car much since it has full LED lighting in it that uses almost no power compared to regular bulbs.
Old Jun 7, 2009 | 12:30 PM
86 vic's Avatar
ill try that also in that pic where did you get that intake tube i would like to get one also my stock ram air intake just aint workin right its chipped and getting a little dry rotted
Old Jun 7, 2009 | 12:49 PM
Old Sep 23, 2009 | 03:20 PM
PatrickNaples's Avatar
Default interior lights stay on
Hi, my interior lights stay on all the time. If I remove all 4 door jamb switches, the light should turn off , right??? I did remove the switches but the lights did go off ... so there must be some other problem in the system somewhere right?
Are there any relays or something that controlls the interior lights? Where do I get cheap used door jamb switches?
I got a '89 Grand Marquis
Thx for your help !!!!
Patrick
Old Sep 23, 2009 | 05:49 PM
make sure the headlight switch is not rotated all the way past the click. if it is, the interior lights will stay on.
Old Sep 23, 2009 | 07:39 PM
Hi thanks for the answere, but it didn't work ...could the headlight switch be broken? the door jamb switches work - checked them all ...
what now? get a new headlight switch? How do I get out the headlight switch?
thx
Patrick
Old Sep 23, 2009 | 09:32 PM
if the door jam switches are not properly adjusted out far enough so that the door will press it in when shut, that could cause it as well. The headlight switch could be the problem as well. It's not too hard to replace either. Try disconnecting the wire harness to the headlight switch, if the lights go out then, that was the problem. If not, it's one of the door switches.
Bellwether11
Mar 15, 2013 02:51 PM
2001GTTT
Mar 7, 2011 05:09 AM
kaos008
Sep 30, 2009 04:33 PM
