need Help with Sable air Conditioning problem
Old May 3, 2009 | 01:19 PM
lbailey's Avatar
Default need Help with Sable air Conditioning problem
I have a 1994 Mercury Sable wagon that has air conditioning problems staying cold.The high pressure line was replaced last year' I put in freeon/uv kit in and found no leaks. Just recharged air again with red dye kit and had temp nice and cold (44 degrees) . After only one day air is running hot again. I once again checked everywhere under the hood for leaks and can't find any red dye showing . Any ideas?? I need to get car fixed ASAP
Old May 3, 2009 | 04:05 PM
if the valves are loose that will leak out pretty quick. also, you'll need to check the entire system for leaks, including the evaporator... usually accessible behind the glove box on most vehicles. If you have checked every inch of the rest of the system, that probably means that the leak is in the compressor itself or the evaporator core in the dash.
sheriya
Mar 28, 2013 01:52 AM
Nailz717
Jul 4, 2011 12:14 PM
hugh9222
Apr 23, 2011 11:14 AM
MercurySchoch
Apr 15, 2011 03:53 PM
cnwrails
Aug 5, 2010 07:07 PM
