Strange Altinator problem:(
Old Jun 8, 2008 | 12:59 AM
Mercurytaxiguy's Avatar
I Have a 1996 Mercury Sable, and I am having a problem with my altinator kicking out at 2000 RPM. Brushes and regulator are fine. Anyone got any ideas? Thanks.
Old Jun 8, 2008 | 04:35 PM
MercuryMan's Avatar
When you say Kicking Out..just what does than mean our Canadian Friend.
MercuryMan [img]smileys/smiley16.gif[/img]
Old Jun 13, 2008 | 11:29 AM
The Altinator turns off at 2000RPMs and the viechle starts running off battery power, until the RPMs drop below 2000 again then the Altinator turns back on.The viechle runs fine until the battery dies.
Old Jul 2, 2008 | 09:56 AM
scott89racin's Avatar
try checking the cable from the battery to the alternator. It is a common problem they get cooroded or loosen. That is where I would start first.
Old Jul 5, 2008 | 02:34 AM
Fixed problem, I did have to change out the entire altinator, no way around it, I guess you could buy a core because the brushes and regulator were still good.
Old Jul 9, 2008 | 09:39 AM
jason sereiko's Avatar
it was the voltage regulator in the alternator. They can not be changed on these because the parts are not readily available like they use to be in the old days when rebuildable kits were on the market
Old Dec 6, 2008 | 06:30 AM
ramit98's Avatar
by what he''''s saying i''''d sat the rotor was bad and a wire was sepperating inside when rpm got higher seen it many times Edited by: ramit98
Mercuryowner1
Dec 25, 2013 07:53 PM
New Mercury Owner
Oct 6, 2009 04:44 PM
AndrewSmith
Jul 4, 2009 05:22 PM
kbsmom
Aug 13, 2008 06:30 PM
dmddfkc
Aug 7, 2007 10:11 AM
