1989 Marquis Idle problem
Hi all,
My 1989 Marquis idle is so low it does not start properly in the cold and then once warmed up the idle seems too high for a normalidle.I need to give a little gas for the engine to warm up and run. I have read through the forum and based on the posts removed and cleaned the IAC valve which cleared the problem for about a 1/2 day and it has returned. Other wise the car runs very well. Is there a test on the leads of the IAC to confirm it is good? I will say it was very dirty when I cleaned it. I am also open to other suggestions.
John
